evotechcorp
evotechcorp
Just received my new G3 controller and have some newbie questions... First I expected the controller to come with at minimum a wiring diagram but no such luck, also where is the documentation regarding inputs / outputs and correlation between them? For instance the system will be on a plasma water table, In an ideal world I want to push a button on the pendant (preferably on the screen . controller) that will trigger an output to open the table drain valves, as an alternate I want to be able to insert an M-code that will provide the same function so if i'm cutting small parts the table will drain at the end of the program. Would also be a fill button that would open the same valves and turn on a pump to fill the table until the controller receives an input signal from the float switch that the table is full at which time the valves close and pump turns off. I know how to easily do this on my other industrial controls using if/then/else statements but i'm just not finding the documentation I need to understand the controller logic... It could be that i'm just expecting too much from the control, i'm used to running Haas machines where you can open up the electrical manual and literally add any accessory you want and create the logic for it via parameters... Any help would be much appreciated
