Hi All,
Just wanted to see if any one has had the same issues and if there were able to resolve. I have recently purchased the G3 Touch and fitted it to a Mill. I am currently have issues with:
G3 Touch Usage:
Overall at the moment, I find the Touch unit quite good, it is a bit tight on the inside for connection additional devices, but overall a good work flow.
- USB connection Issue USB seem to drop out quite regular, I have tried plugging in directly as opposed to the bottom connection but this did not seem to resolve the issue. I have a X-Keys programmed keyboard that I use on my other 2 machines that may contribute to the issue as it became a bit more stable once removed. I do not have this issue on the other 2 G3 with this keyboard, They are only Running software version 4.0
- G3 Touch Total Freeze, I have had this G3 Touch controller freeze up completely twice, the screen was unresponsive and I had to reboot the MASSO, Has anyone else experienced this?
- Masso Link 2.0, I have tried to use the new version of the Masso Link 2 with the G3 Touch (V4.01), I have trouble getting it to connect and when it does it seems to freeze up. I had to stop the Mill part way through a program cycle, Masso link froze at the 80% mark and would not update, I had to reboot. I have stopped trying to use the Masso Link with the Touch and reverted back to manually loading it onto the USB. I am currently using Masso link 1.6 with my other G3 (V4.0) and it seems to be quite robust. Please advise if there is anything you can suggest to resolve
G3 Touch Usage:
- If using the screen in portrait mode, during a program, is it possible to adjust the Spindle/Feed rates without and external keyboard while in the F2 screen. Is there future plans to include a slider for Spindle and Feed rate like on the F3 Screen for during a program. Is there an easy way that I am missing? I know it can be done with the F11, F12, - & + keys.
- When a new software version needs to be installed, I believe, currently you need to power cycle the Masso and Press F1 repeatably, can this be done on the touch without an external keyboard.
