masso info needed
chessie
chessie
hi i have a mill and a lathe conversion ,using steppers and currently run on mach3
i was thinking of mach4 but then came across some masso ,centroid ,video's . i then saw i had another avenue to explore.
i'm thinking of buying for the lathe first ,
will it fulfil my needs
i use fusion 360 for cad cam
cut threads using g76
want true css ,which matches changing rpm with feed
i use g95 feed per rev
confidence masso is here for the long term
i have a brain on mach3 which throws an e stop if the spindle stalls or goes under 70% of called for rpm . this stops me mashing tools into stock that's not rotating . is anything like this possible using the masso?
i have a single pulse on the spindle for screw cutting ,would i have to change this for an encoder ?
cheers
Hi Chessie
Masso Lathe Post processor for Fusion 360 available here https://docs.masso.com.au/cam-post-processors/fusion-360
Sorry not supported
Masso does support G76 but has a built in wizards one of which is threading. You can also use you Cam Software to create the required tool paths.
https://docs.masso.com.au/getting-s...lathe-conversational-wizards#threading-wizard
Yes G96 is supported
https://docs.masso.com.au/supported-g-codes/g96-turn-on-constant-surface-speed-css
G95 is supported.
https://docs.masso.com.au/supported-g-codes/g95-feed-per-revolution
Not going anywhere.
Masso does not support this.
Masso requires full quadrature encoder signals for multi pass threading.
https://docs.masso.com.au/wiring-and-setup/setup-and-calibration/masso-optical-encoder
https://docs.masso.com.au/wiring-and-setup/setup-and-calibration/spindle-rpm-encoder
