MASSO inputs... only PNP or NPN also
skibbe
Skibbe
Do the inputs only accept positive voltage to trigger (PNP)? or can we ground the inputs to trigger them as well (NPN)?
Hi @skibbe
You can use either PNP or NPN sensors. If you use NPN then you need to provide a voltage to the input through a pullup resistor and the NPN sensor will ground the input taking it low. You can then invert the input to make it work as you want.
I use NPN sensors on mine, inverting the input and they have built in resistors which made wiring them easy.
Hi @skibbe
5.6K is a good all round value to use.
I wrote a document on the weekend that might help with identifying and wiring homing sensors. Have a look and see if helps.
  • Identifing-homing-sensors-and-how-to-wire-them.pdf
segoman-designs
SegoMan DeSigns
Quote from CNCnutz on November 18, 2019, 8:49 pm
Hi @skibbe
Peter,
What is the recommended watt rating for these resistors?
@segoman-designs
It really doesn't matter as these are logic levels only and worst case scenario you couldn't even pull 1/8th of a watt.
If you go 1/4 watt you will be good.
spudgun
New member
Hi Peter, Ive also been watching your videos on getting me up to speed on the MASSO. They are brilliant. I love how you intentionally show things going wrong to show what to do to fix them. Extremely well presented and easy to digest.
I was wondering whether there was a video on configuring the X,Y and Z motors?
Thanks Spudgun,
The problem is that you don't learn when thigs go right. Only when you do it wrong and have to sort it out do you learn.
There are no videos on motor configuration.
