Masso link 1.5
lifeofriley
lifeofriley
I'm having no luck opening masso link 1.5
When I click on Masso link a Window opens that says .
"Windows cannot access the specified device, path or file. You may not have the appropriate permission to access the item."
In the winzip file there is a visual basic file but there is no info as to what to do with it.
Can anyone tell me how to get it working.
Thanks.
Hi lifeofriley
Extract all files to the same folder.
https://docs.masso.com.au/getting-started-guides/machining-with-masso/wi-fi-connectivity
  • Download the ZIP file of the latest version of the MASSO Link software and extract all the files in a folder.
  • Next double click MASSO Link icon to start the software.
Masso link software does not require connection to to Masso to open. If you cannot get the Link software to open then it is a PC issue. The message you have received seems to indicate some type of permissions problem.
astfgl
astfgl
Make sure you extract the files to a folder. Depending on which version of Windows you have, the executable does not like running from inside the ZIP.
