Masso Plasma Cutter Proma THC advice please
marvelafrica
MarvelAfrica
Hi Guys,
I am not sure if I am missing something small here but i am unable to get my Proma THC to work while in a cutting process.
Here is what i have in place.
Proma connected to Masso on a separate power supply.
I have resistors in place on the 3 input signals from the Proma.
I suspected it was noise so i rebuilt the whole table with shielded wire and followed earthing guidelines.
Set the Proma to same settings as Ross suggested in his video found here on the forum.
I am Running the latest version of Masso on my G3.
When i put the Proma in Test mode, enable THC and start the torch (test with Plasma Off) i get the response i would expect,
Z axxes moves up and down as per the test sequence from the Proma.
I have lowered and increased the voltage on the Proma to try and see if that effects any changes.
While the system is in a cutting sequence i can see the THC switches on on the Masso screen, i can see the Proma giving up or down commands (LED's on the Proma),
but i am not detecting any Z axes movement, either on screen or on a piece of tape on the stepper motor, when the machine is a cut height of example
1.5mm i can see the distance to the work piece increases in a straight line (Heat warped sheet), the Proma says it must go down but the Z does not react at all.
at this point THC option is on the Masso as set by the G-Code, the Z reading on screen stays at cut height with no movement up and down.
I am unsure if i am missing a step here, or i have neglected to setup something.
What is different to the documentation, my Pull down resistors is higher than 5.6k Ohm, i believe they are 8k Ohm
Any guidance or advice would be highly appreciated.
marvelafrica
MarvelAfrica
An update, I have just updated the wiring to the system to follow the bellow suggestions, with the Common from the Proma to ground and also grounding the Masso to the common ground.
unfortunately that also did not affect any change as the Masso still do not react to the signals coming from the Proma.
Proma Inputs are wired to input 13,14,15 on the masso, 13 being up (THC 1), 14 Being Arch Ok, 15being up (THC 2).
Any other ideas please :)
marvelafrica
MarvelAfrica
here is a sample of the G-code on a 150mm straight line as generated by sheetcam.
N0010 (Filename: test line.tap)
N0020 (Post processor: MASSO Plasma (with THC).scpost)
N0030 (Date: 05/06/2021)
N0040 G21 (Units: Metric)
N0050 G90
N0060 M666 (---THC off---)
N0070 (Part: test line)
N0080 (Operation: Outside Offset, Colour 250, T1: Plasma, 1.5 mm kerf)
N0090 G00 X0.0000 Y0.0000
N0100 (---Take Z reference---)
N0110 G38.2 Z-100 F500.0
N0120 G92 Z0.0
N0130 (---Go to pierce height---)
N0140 G00 Z2.0000
N0150 M03 (---Torch ON---)
N0160 G04 P500
N0170 (---Go to cutting height---)
N0180 Z1.5000
N0190 G01 F100.0
N0200 F1500.0
N0210 M667 (---THC on---)
N0220 X150.0000
N0230 M666 (---THC OFF---)
N0240 M05 (---Torch OFF---)
N0250 G04 P300
N0260 G00 Z10.0000
N0270 X0.0000
N0280 M05 M30 (---End of program---)
