My machine has been running good now for some time. Yesterday I powered up, homed the machine, turned on the spindle, spindle coolant on, when I turned mister on, everything shutdown. Would not respond to any more M codes, MASSO was locked up. I pulled the relay output wire, feeding the mister relay, and rebooted the machine. Powered up, all running good. Went to F1 toggled the relay output for the mister to H and everything shut down. Remember there is now NOTHING connected to THAT output. The relay is coil is rated @ 103 ohms, 117ma, at 12V, which is well under the 400ma spec for relays. Digikey part no 255-1828-ND.
Did I break it? If so, how do I fix it? Do you recommend I add fly-back diodes to all relay coils?
Thanks for your help.
Ben
Ben
