buckmaster1967
Buckmaster1967
Hello,
I have a 10ft water table with a Hypertherm 45 cutter, Masso G2, 3 axis controler with Price HVHC 10 HT Controller.
Finally having a day off, I decided to work on my Price height controller. Received some good advice from here and was excited to play. First I need to cut out a sign. On about the 3rd line of the run, the torch would go down to the top of the metal, the arc would light and just set there. Could not figure out the issue. Tried a few of my latest cuts that ran fine before. Same thing with them. I started reversing my steps since my last good cut. It was the latest update 3.47.4 . I tries everything, new install of update, downloaded it again, changed thumb drives. Always the same results. I decided to down grade to my last update Masso v3.44. Table is working great once again. All the cuts the failed, now works. Of course still have not fixed the height controller, just thankful the table is cutting again.
