I have been converting over an existing machine with a Masso G3 4 axis. I have it all running OK except for the Spindle speed control. I have spent time reading through the forums and found a couple of similar post but still can not fix it. I have watched the video in the documents, my set up has the same VFD as in the video. I worked through all the steps and at the end, it would still not work. I plugged a 9v battery to the wire that connected to the -Ve and pin 1 and it worked. If I put the multi meter on the -Ve and Pin 1 on Masso, it showed 68mV.
can some one please offer me some assistance. I changed the VFD settings just to go back to the front panel on VFD for now.
Could this be a faulty unit?
regards
Damien
regards
Damien
