safeairone
safeairone
Setting up Masso G3 + Gecko G320X Servo Driver + KL34-180-72 servo with AMT102X encoder on the bench prior to installation on my machine.
Part of that process outlined in the Gecko G320X user manual is determination of the optimal encoder line count setting for the AMT102X encoder. This is the only piece of the puzzle I'm missing. If my understanding is correct, line 4 in the excerpt from the G320X manual shown below should be the maximum step pulse frequency the Masso G3 is capable of putting out. Is this correct? If so, where do I find this information?
Thanks for any insight anyone can shed on this!
--Mark
To determine the optimal encoder line count, please follow the instructions below.
1.) Determine the motor s no load RPM (4000)
2.) Calculate rated RPM as 80% of no load RPM (3200)
3.) Divide (#2) by 60 to get revolutions per second (53.33)
4.) Determine the CNC program s maximum step pulse frequency (in Hz) (???)
5.) Divide (#4) by (#3), which will give you the maximum counts per revolution
6.) Divide (#5) by 4, which will give you the max line count
7.) Pick the first standard line count below (#6)
--Mark
