thewoodtinkerer
TheWoodTinkerer
My name is Marc. I've built a mostly wooden CNC with 1060 x 760 x 100mm travel, a 2.2kW aircooled spindle and Nema23 steppers on each axis. The motion is chain driven and the linear guides are 4 regular bearings on each skid at 90 , running on POM rods, lying in round grooves on the upper and lower edge of the axis' rails. The Z-axis uses a 1605 ballscrew and the same kind of linear rail as the other axis.
This machine will mainly cut and carve wood and foam. Going with MASSO was a last minute decision after evaluating many other options. So far, I'm very pleased with how the machine performs. I run it at 60% of the maximum current for the steppers and also reduced the maximum current of the VFD. Yesterday, I've planed the wasteboard which took 25 minutes and the steppers and spindle were barely warm.
The next project will be a fully enclosed 3-axis CNC router for the makerspace where I'm a part time coach. We'll see if they'll agree to go with MASSO?
