MPG e-stop not working
grg_p
grg_p
When n/c is showing reverse and high when open. My e-stop will not work when MPG is plugged in. Is the MPG e-stop wired in series or am I missing something. Thanks
grg_p
grg_p
My e-stop works fine when MPG is not plug in. When pendent is plug in the e-stop is high when open and low when closed on in f1 from pendent. I checked e-stop on pendent and switch is n/c when out and open when pressed. What is the pin out for mpg. Thanks
@grg_p
When you connect the MPG to Masso, the E-Stop has to be connected to Masso E-Stop Pin 1. When the MPG is removed the E-Stop has to be connected to E-Stop Pin 2. You can't run it both ways without swapping the pins on the Masso E-Stop connector.
