MPG pendent resolution. .0005, .001, .0010
triump
Triump
Hi there,
The resolution on the pendant is .001, .010, .100. However, the display shows .0005, .001, .0010. The machine also moves .0005, .001, .0010. How can that be change to match the resoulution on the pendant.
Triump
triump
Triump
The one I purchased from Masso. The mpg does show x1, x10, x100. However, when I select x1 it shows .0005 on the Masso screen.
actually this is the resolution that most of the users requested as being the most useful, that is why we have these predefined values.
right now its fixed, but I have added your request to the development list and see if this can be set in the MASSO settings in F1 screen in the future. So whats your preferred values?
triump
Triump
Woukd be nice if they matched the pendant. X1, x10, x100 instead of x0.5, x1, x10. Not a big issue really. I can just put a label on the pendant.
we will also see how others want the numbers to be and then in the future we can change these if a lot of people are requesting the changes.
tracar
Tracar
every other controller i have you can manually set the increments to what ever you want, for each channel of the selector knob, that would be the best way to have it. this pendant really has some bugs as it looses count when reeling fast. (reel it to work 0 position, ,turn off from x , re calibrate dial to 0, turn back to x and reel away back and fourth, when i get back to zero in the wheel its no where near the workplace zero where it was set.
Hi
i am using masso mill for af hobby maschine, is it possible in an later upgrade of the software, to have an option to change the ressolution in metric from 0.01 0.1 and 0.5 to 0.001, 0.01 and 0.1mm as is common on the milling maschines i run for work ??
