MPG Will not work with my Masso
deese
Deese
I have connected an mpg the same unit that masso and cnc4pc sell to my controller and it will not work. It will move the axis one click at a time but if you turn it any faster it does nothing. On the setup screen the inputs are working properly for the x,y,z,and the res1,res2,res3, the mpga,and mpgb flicker when you turn the mpg. The mpg test's good on the bench with a 5v square wave signal on the A and the B. This is the second mpg I have tried and they have both behaved exactly the same.
deese
Deese
I put it back on the machine and retested,it will only jog one pulse at a time in the positive direction,it will not move at all in the negative. Took mpg back to the bench,back on the scope and it is working perfectly 5v sq wave A,B, 90 degrees out of phase. Now what?
sam
Sam
Hi there Deese,
Have just been going through setting up that myself and am still very inexperienced with Masso, so not sure how much help I am going to be.
I did have similar issues you describe and found the issue was that the axis/s had reached the end of the limits set in their axis's. They still had plenty of travel physically, but since I hadn't adjusted them after first starting Masso the had some arbitrary values. I think they are softlimits. In the Setup (F1) on the left hand side there is a line (double click button) for each axis. Double click and in the popup you can change these limits and save them.
Sorry if that's not it, but thought it might be worth a try.
Good Luck with it.
@deese
Test using jogging with your mouse will be the first best test and if it moves backward and forward then check with the MPG.
If your axis only moves in one direction you might have this little problem.
deese
Deese
I have soft limits set up in my machine,I have been using it for some time now, I'm just now getting around to putting the mpg on it. I'll double check it but it doesn't really move in any direction it only moves positive one click at a time. If you spin up the mpg it does nothing
@deese
It's hard to know who is at what stage of their build and what they have tested so far.
Do you have a G2 or G3 and if you post your settings file I will test and see how it behaves on my machine.
deese
Deese
Quote from CNCnutz on March 25, 2020, 10:00 am
@deese
Its a g2 I believe you have my settings file,serial number and so forth from our earlier conversation about the jogging while tool change is active offsets changing business.
@deese
I tracked down the topic you mentioned and loaded your settings file.
Everything works as it should. I can only suggest you contact the seller you purchased your pendent from and talk to them.
Not all of the MPG's that look like the Masso one actually work. I don't know what the actual difference is in the outputs signals but I know that mine outputs 9 volt pulses on my 12 volt PSU and is a 4 wire unit A,B 0v & Vcc. I have read that MPG's come in npn & pnp configurations but what the difference is I don't know.
deese
Deese
Quote from CNCnutz on March 25, 2020, 1:45 pm
@deese
I am going to try to feed the mpg with 12v on the bench,I believe it will accept up to 24vdc. Maybe I should request an edit to the documentation page on the website,it is very clear on the mpg page if your mpg takes 5 volts be sure to use a voltage regulator so you don't damage it. That implies masso will accept 5v sq wave signals. Maybe the threshold is higher than 5v in the controller for those inputs. I don't know if it was you who replied to my email I sent to tech support about this and the reply was "It could be anything" that is not really a viable answer. This is not a hobby for me,I am experienced in industrial electronics,I just happen to have a masso on one of my routers. I don't feel like I should have to experiment with voltages to try to get my mpg to work.
@deese
I should mention that I wasn't suggesting that the voltage was the cause of the issue. I mentioned it to illustrate that the MPG was a different unit from the one Masso supplies
The fact that you are seeing the A & B inputs changing probably means that they are working but maybe they don't output the correct sequence.
Another user having the same issue with a third party said they solved their issue by changing the MPG from an NPN unit to a PNP. What the difference is I don't know. Maybe you will be able to tell me because my research to date has turned up nothing. I don't know if this is your problem or not or even if that is the reason.
https://www.masso.com.au/forums/topic/pendant-issue/?part=1
@cncnutz
Check out this web site. Does a pretty good job of explaining pnp ( sinking ). and npn (sourcing ) inputs and outputs. When I bua a Plc for a project I always get sinking in and sinking out. It's the easiest for me to understand cause all I have to do is supply a pos v to the terminal for it to work. I do believe Masso is sinking inputs and I can't remember how I wired the outputs so not sure there.
(https://automation-insights.blog/20...g-fundamentals-back-to-the-basics-npn-vs-pnp/)
deese
Deese
Quote from CNCnutz on March 26, 2020, 12:42 am
@deese
So to my knowledge there are three basic types of encoders.
Open collector NPN this type pulls the input to 0 volts. So if your controller maintained vcc,or 5v,or 12v whatever on a circuit and wanted that circuit pulled to 0 volt to operate it thats what you want.
This type is also called pullup in some units because they use a resistor to pullup the collector(the a,b inputs) to vcc,5v,12v whatever. So when you turn the encoder you get a sq wave from 0v to Vcc.
Problem with this type is the pullup resistor has to be high value to keep current draw low on the NPN transistor when it pulls the signal to 0V, so when you try to use this type with any length of cable
the resistance has to push voltage into the cable passively,and the npn pulls it down actively so you get a really ugly signal on any cable with any parasitic capacitance,and inductance, which is every cable on earth.
Next
Push Pull Type has a totem pole arrangement of pnp,and npn transistors. The input(a,b) is connected at the center so that the pnp pushes voltage into the line,and the npn pulls the voltage down.
So with this type you have active pushing,and pulling of the voltage in the line and it will give a good signal through a cable. Albeit some overshoot on the leading edge of the sq wave,which also come through as artifacts
in your sq wave at the overlap of the a,and b signals. The more parasitics on the cable the worse the artifacts,and overshoot.
Next
Continuation of the push pull is the differential line driver type. Thats where your A,B,-A,-B, come in to play The a,b are the same as push pull signal starts at 0v and is driven to Vcc, in the differential side -a,-b starts
at Vcc and is pulled to 0V so if your controller will accept the differential signals it is supposed to be more reliable.
So my MPG uses a differential line driver type encoder,which I am using the A,B, signals which switch from 0V to Vcc. I am not using the inverted inputs per the masso documentation.
I have connected my mpg to 12 volts this morning,on the bench and tested it. It is perfect,as it was with 5 volts also.
I installed it into my control cabinet,and it behaves exactly as it has the last half a dozen times,no movement in neg direction,only moves positive if you jog it one click at a time or very slow.
I have taken the oscilloscope out to the shop floor and probed the signals at the db15 port on masso,and I have a perfect 12v square wave A,B quadrature signal on pins 3,an 4. With the mpg connected and turning.
With the MPG disconnected.
I have installed a db15 cable and a breakout card so that I could test the inputs of the db15 port. Measured from the db15 body-Ve, pin 1 is controller voltage 24vdc,all other pins are at 0Volts .
I have to assume this is what it should be.
In that other post there was talk about the opto couplers being damaged, arent they socketed in the masso? That would be worth while to swap out I think. I have some dip6 optos that are pretty standard.
I dont know what the masso uses but I could pull the cover off and check.
@deese
Thank you for the explanation. I was unsure if the PNP / NPN was to do with the electrical characteristics of the MPG interface or if it described a particular output signal format.
The optocouple IC's in Masso are all socketed but the fact that you are seeing Masso respond on both the A & B to the signals coming from the MPG would indicate that they are working.
https://www.masso.com.au/masso-documentation/?section=replacing-optocouplers
I do not have a scope to check what the output signal is but if I turn the MPG very slowly I can see how the A & B behave. In my test I am moving the MPG only 1 division at a time and I can see by looking at the A & B signals that each pulse is made up of 4 states. I had to hold the MPG as it moved between the start and end of the division so I could see each state as it went.
This is with the MPG moving in the -ve direction
  1. A Low B Low (Start)
  2. A High B Low
  3. A High B High
  4. A Low B High
  5. A Low B Low (End)
This is with the MPG moving in the +ve direction
  2. A Low B High
  3. A High B High
  4. A High B Low
Maybe you can do the same test with your MPG and see what you get. I think this is where the mystery will be found.
deese
Deese
Quote from CNCnutz on March 26, 2020, 10:32 am
@deese
  2. A High B Low
  3. A High B High
  4. A Low B High
  2. A Low B High
  3. A High B High
  4. A High B Low
I would say that is exactly what it should be,the signals are offset in time 90 degrees a and b overlap 50 percent. I do not believe my controller will display this pattern, but my mpg is outputting the correct signals verified on the scope. I am home now but in the morning I'll test that as the A,B,signals go high the inputs track on the setup screen. But I feel very confident they do not,if I recall they are just random flickering..
deese
Deese
@deese
  2. A High B Low
  3. A High B High
  4. A Low B High
  2. A Low B High
  3. A High B High
  4. A High B Low
On the setup screen in Masso: Ok I tested that this morning and it is extremely random at best,with the B signal flickering 10 times as much as the A signal,and never in the correct order. Its actually difficult to get the A to flash at all and it does not flash turning slow,you have to snap the mpg dial back and forth or spin it up to get a response on A.
Mpg back at the scope again,again: I took pictures this time. The A and B are in perfect harmony,amplitude correct,timing correct. In the pictures the vertical divisions are 5 volts,and the time/horizontal is 200uS per division. The trigger is set to rising edge on channel A which is the red trace,and channel B is the yellow trace. The scope is set to single shot to capture the individual event,I am clicking the MPG one detent. In the first pictue you will see the red trace goes first which is clockwise or positive rotation of the MPG dial,and the next picture will show the yellow trace will have went first for counterclockwise or negative rotation of the MPG.
@deese
The reason for the random flickering you see on the F1 screen is the Masso screen refresh rate.
To see the A & B input states you need to minutely control the MPG and move it at glacial speed. Easy to do with your thumb. You should see 4 definite states on the F1 screen matching what you see on the Oscilloscope between each division of the MPG.
If I get time I will video it for you later today so you can see what I mean.
deese
Deese
I did that,it will not display like that no matter how slow you turn it. There is a fault with my optos or the controller,but I have had it for some time and just now tried the mpg so there won't be any warranty or probably any fix for it. I just won't have an mpg. If it wasn't on a machine making parts I would mail it to you and you could have at it.
@deese
All the optocouples on Masso are the same so you can swap them of you think you have faulty ones. Your probably not using the rotary encoder so those would be good ones to use. U33, U34 & U35
MPG A & B are U36 & U37
Also check the ground of your pendant as the Masso pendant gets its -ve through the shell of the pendant and not one of the pins. It's really curious.
deese
Deese
I am posting an update on this topic. I have ordered the pnp encoder and swapped out my original encoder. I reconnected the mpg and I get the exact same result. It does not work! The mpg a and b channels change state when you turn the mpg on the f1 screen. I can achieve every combination of state of high and low now. But I can not always get the exact order peter outlined above but very close. I have a g2 and I dont know about the refresh rate so it may be working fine. There is no explanation other than my controller is faulty. I changed out the optos for the a and b channels that didnt help. The machine will jog and rapid from the keyboard no problem but it will not mpg. I wish I had checked every funtionality of the control immediately when I bought it. Now I have a control that mpg doesnt work, and no one is going to do anything about it.
It s about time that we got a proper description of the different between pnp, and npn signals from prox s and other devices. Here is my most likely scewed understanding of how it works
pnp, positive, negative ,positive. The device receives a positive current into it and when triggered sends out a positive current. This means it is sourcing. A sourcing device is compatible with a sinking device which I do believe Masso inputs are.
npn, negative ,positive ,negative, is the opposite. Negative current in and negative current out. That makes it sinking so it is compatible to a sourcing input. Not readily compatible with masso. Of course there are various wiring tricks to make incompatible devices work mostly with pull up resistors.
@zombieengineer , how about weighing in on this subject and straightening all of us out.
