Nearly 12 months of Operation.
lilow
Lilow
To whom concerned, in April I think it is 12 months since I got this board to work within the Masso G3 control for Plasma cutting. It was a task that spent many hours trying to decipher comments from CNCnutz and Brezzy and then Ross. Now after these months I can report that it works with Masso G3. It all comes from a simple board, it is how it is understood. I have been challenged by others, but the results collected are beyond belief. Only one person, SeroMann Designs contacted me. He has it running in the USA.
A photo extra is the quality of a 3D Tig machine weld using the same comparator.
I like the new screen.
Thanks to all those guys.
Cheers.
aussiemike
aussiemike
Hi Lilow, I didn t know Masso did CNC welding. The weld in that picture is impressive. Can you get video of it in action?
Mike
lilow
Lilow
@aussiemike
Masso supply a controller, what you do with it after purchase is up to the client.
The welding photo is a sample of the weld produced using the board shown (photo) for arc voltage height control.
( DeckCNC Gen2 controller used, it took 7 years to develop the 3D Tig welding machine based around a Cyclomatic AVHC, replacement cost = $10K US )
The DeskCNC control might be replaced with the Masso when they can supply a 3D screen.
The same board is used in the plasma with the Masso controller.
Cheers.
jcoldon
jcoldon
Get masso to add the proper THC control it be real nice up down inputs lack control. voltage is not always coming out of the plasma dead on. like cutting off edge over a hole Expand metal
this is what THC should be able to do . not just read voltage
Automatic or manual control of the cutting sequence
Sample and Hold voltage mode - THC measures the voltage at the end of the AVC Delay
and uses it as a set point for the remainder of the cut.
Automatic Collision Avoidance, provided that the Ohmic sensor is used. This safety feature
allows the control to automatically adjust the torch height during a cut to help prevent
torch crashes
THC OFF control from CNC (on corners, end of cut, circle of small radius)
Programmable arc voltage limiter Lock Head Down to help prevent torch crashing when
crossing a kerf, corners, end of cut
Programmable arc voltage control loop dynamic (gain) value
Shot mode can use for marking centers of the circles
Works with Float Head and Ohmic sensors for IHS simultaneously
Built in Testing of the cutting sequence
Integrated diagnostic system informs the operator of the errors that occurred
Programmable automatic positioner speed
Programmable jog positioner speed
Programmable IHS (initial height sensing) touch speed
Programmable acceleration
Programmable arc transfer height
Programmable pierce height
Programmable pierce time
Programmable cutting height
Programmable AVC (automatic voltage control) delay time
Programmable crossover (IHS start) height (high-to-low speed transition point)
Programmable torch retract height
Programmable torch retract delay
Programmable maximum torch slide length (Soft Limit)
Easy setup for Float Head switch offset value
lilow
Lilow
@jcoldon
Automatic or manual control of the cutting sequence ( can be achieve already )
and uses it as a set point for the remainder of the cut. ( the voltage mode changes during cutting, pre-set to what and adjust on the fly )
allows the control to automatically adjust the torch height during a cut to help prevent ( never had a collision in 22 years cutting )
torch crashes
THC OFF control from CNC (on corners, end of cut, circle of small radius ( this is never needed if programmed correctly )
crossing a kerf, corners, end of cut ( the machine can cross a pre-cut parts without crashing, comes back to your programming and accessories used )
Programmable arc voltage control loop dynamic (gain) value ( maybe good, but can't see any advantage )
Shot mode can use for marking centers of the circles ( what's this about ? )
Works with Float Head and Ohmic sensors for IHS simultaneously ( why ?? , it does know )
Built in Testing of the cutting sequence ( a good operator has already programmed the sequence with some sort of knowledge)
Integrated diagnostic system informs the operator of the errors that occurred ( never ever thought that this would be an issue if the machine is built well )
Programmable automatic positioner speed ( why ?? , the jog speed is on the screen )
Programmable jog positioner speed ( change your jog speed in F1)
Programmable IHS (initial height sensing) touch speed ( can be done already )
Programmable acceleration ( done in F1 )
Programmable arc transfer height ( can be changed on the fly with a good THC )
Programmable pierce height ( all done in the initial program )
Programmable pierce time ( all done in the initial program )
Programmable cutting height ( all done in the initial program )
Programmable AVC (automatic voltage control) delay time ( all done in the initial program )
Programmable crossover (IHS start) height (high-to-low speed transition point) ( ??? )
Programmable torch retract height ( all done in the initial program, but can be set in F1 )
Programmable torch retract delay ( all done in the initial program )
Programmable maximum torch slide length (Soft Limit) ( F1 )
Easy setup for Float Head switch offset value ( in F1 again )
I think you had better take this to Masso , they will not understand as I certainly don't.
Keep it simple.
Cheers. As I see this.
@lilow
A couple of questions with respect to your setup:
  • What filtering / clamping of the arc voltage do you apply before using the signal with the DT-115 comparator board?
  • Two of the comparator channels are used for Arc OK detection - what is the voltage range you use?
  • For the Raise/Lower comparators channels do you use the same reference voltage? (is there any dead-band between raise/lower?)
  • What is the ratio between the THC feed rate and the cut feed rate?
    • My understanding is this ratio impacts the THC performance (it becomes the limit of the slope the torch can raise/lower). It needs to be high enough for the torch to follow the contour of the metal sheet being cut but not too high that the torch comes racing down when crossing a previous cut.
lilow
Lilow
@zombieengineer
  • Plasma arc voltage = 108v, divided voltage at 13.5 :1, ( 8v ) read voltage set to around 7.3v. ( my own built divider board to a Cebora Prof 122 machine )
  • Two channels are set for Arc OK, this I don't use on the Masso, F1 screen Arc OK set to a high (red).
  • Not connected to the Masso imputs.
  • The high / low of those 2 channels can set from 0 to 30 volts, or a voltage to cover the spectrum of the set voltage to cover the dead band voltages with a margin either way.
  • If set voltage is ( as mentioned above ) 7.3v, OK low could be set to 5V, OK high could be set to 9.5v.
  • The same reference voltage is the read voltage set, this voltage can be adjusted anytime during cutting if a higher or lower status is required.
  • The dead band is set to around 0.004 Volts, the speed of this reaction is determined by the capacitor value on the input side of the comparator board.
  • The THC feed rate is set with the M667 F??
  • Normally for 4mm plate, this would be F50mm, 3mm / F70mm, X y axis speed of 2000 / 2500mm respectively.
    • After 20 years of using this home built CNC Plasma, it becomes a part of life when writing the programs with my own post processor with BobcadCam 17.
    • Cheers, thanks for asking.
jcoldon
jcoldon
Lillow you might want to go back and look at some of your answers like AVC ther no such control in masso or your lillow all you have there is a voltage comparator nothing more cutting in the 2500 mm speed
that no cut speed that for cutting 10 ga and 3/16 ... i can do that with no THC... hypertherm pm 85 45 amp 16 ga steel cuts at 350 ipm that 8900 mm per min to you and i rapid at 31000 mm per min that 1200 inch per min my z axis does 400 ipm acceleration rates of 35 to 50
. that voltage comparator crash a torch it simply never read that fast . lots of things on the list i posted you answered wrong .Ycant be going in g code to set responce rate that nuts do a new repost for changes .
thers no ohmic and torch slide as back up feature . automatic positioner speed it not jog speed .Thers no delay settin for thc in masso no g code does that . you cant compare a neuron THC full auto THC control.
With that lilow comparator using up down inputs that be like compare a 1 leg horse to a 4 leg one. You simply have no THC control features in masso other then g code reaction time
this is the very reason why no oem going to use a masso on there tables they know . and the ones that are using proma that work for what they are . And a lot of intervention .
i had a masso G2 3 years ago doing plasma tests i know what masso does . i know have a G3 now i going to give it another go .this time with neuron thc help ..
you might want to read up on THC and the full plasma process that hypertherm has in the books .. your running your table way slower most likely cutting thick steel any THC work for that .
if i can make a neuron run with a masso it be a very good plasma controller . not many controllers do THC like neuron
like i said show me the lillow cut like this neuron video . plasma cnc uccnc + neuron THC 3 P-t.in.ua 066 176 5900 p155@ukr.net - YouTube
lilow
Lilow
@jcoldon
I think you are in for a shock, a 1 legged horse doesn't need a race anymore.
You continue working with what you want to.
You make Neuron work with Masso and then I will believe it, until then don't disqualify others.
Your assumptions leave me in disbelief for a person who appears to be so qualified and then trying to make these THC things work .
Never under estimate the power of needing something to work.
( you will do it, one day )
Now stop mentioning Hypertherm settings, they may not work in the real world, maybe only in their lab.
A lot of users don't even use a Hypertherm.
I looked at Neuron years ago, but you weren't around at the time for any advice.
Lucky I kept going to what I achieved.
Cheers from the Dingo.
lilow
Lilow
@segoman-designs.
It's getting hot again here.
After what I helped you with, some still don't believe.
Just received a few more boards, China slowed everything down with a trade war on everything they buy off us.
Wine, beef, coal, etc.
All over the PM asking did it start from Wuhan ????
Anyway, going to put 5 boards together and put them up.
Then I will know if the Earth is still flat.
Cheers, Dingo still roams.
segoman-designs
SegoMan DeSigns
Quote from Lilow on February 17, 2021, 4:56 pm
@segoman-designs..
The earth may be flat but the metal they call flat is not! Flat metal is an oxymoron or it is when you live in the middle of the not so flat part of Colo.
