Good day to you all. need help regarding exact wiring location in the MASSO with 3 wire hall effect sensor. Any advise is highly appreciated. Thank you all.
The attached wiring should work Dex. Because the technical data on this particular Hall switch is limited there is a possibility it may not work. The reason for this is there is no information on the Hall unit's drive capability. You cannot damage either the Masso or the Hall unit by trying the circuit. Again, it should work but...
