jim-in-michigan
Jim in michigan
I am having trouble with post processors, I have BobCad. I have my lathe working, but I need a program made of a simple turning test piece to load in my masso to see how my lathe will work under control of a g-code prog. So if I could get someone to make me a simple turning prog.would be greatly appreciated. If someone does this the collet on my lathe will only hold 1 1/4 inch Dia. material, don't hace a chuck yet. So if you would make a program with two different diameters and a angle cut.
It would be a great improvement if you could type in more than one line of gcode in MDI on the Masso.
Jim
Jim
