i have a masso G3 controller
How can i turn on,, In this case A axis with a command and stop it with another command for example making M4 turn on my A axis with a feed rate and and the end of program turning it off with an M5 command, in my case my A axis is for my abrasive metering system for my water-jet retrofit, so i need to be able to turn it on with a feed rate and stay on untill my part is cut
i guess my end all is can i wire it up to the spindle side of the masso controller? or how can i achieve this?
masso controller is awesome everything works great, except this little delima,
Thanks for time
Thanks for time
