What is the difference in wiring between the G2 and G3? Thinking about buying one to replace my broken G2. If not a big difference I could have the repaired G2 for backup.
What I meant was the A & B axis now have the same output hardware as the X,Y,Z axis so the wiring is the same across all 5 axis. In the G2 A & B axis were wired differently to the X,Y,Z axis. But as MASSO support answered you can swap from one to the other without having to make changes to the wiring.
