New mini mill conversion.
chucktilbury
chucktilbury
I have a LittleMachineShop 3990 (Sieg X2) mini mill that I am converting. I purchased a 4213 CNC spindle controller from them that converts it to VFD. My problem is that I don't know how to map the signals on the MASSO to the signals on the VFD. The schematic provided with the 4213 shows a 0-10V DC signal, which is clear enough. It also shows a NC (to ground) "start" signal and a NO (also to ground) "forward/reverse" signal. I think these are TTL level signals, though that is not specified in the doc I was provided. Looking at the actual board, there are no optos on any of these inputs.
Looking at the MASSO docs, it looks like I can probably use pin 2 for the direction control, since TTL "low" is current sinking to ground, so that should work.
I don't see anything to use for a "start" signal. I am thinking this would be the same as an "enable" signal. Looking at the F1 setup screen, I don't see an option that looks like it will do that. Anyone have an idea?
Also, I have the following values in the spindle dialog:
Encoder = 100 (there is no encoder, so I don't think this matters)
VFD = checked
Max RPM = 2500 (this is the advertised max speed)
Spin up time = 5 mS (I would set this to zero as I don't think this needs a spin up time)
Spin down time = 0 mS
Any help is appreciated.
Here is a link to the docs for the VFD add-on: https://littlemachineshop.com/images/gallery/instructions/4213CNCSpindleControlUpgradeKit.pdf
The schematic I am referring to is on page 6.
chucktilbury
chucktilbury
Ya know.... After taking another look at everything. The spindle off/on is probably handled by changing the V on the 0-10V line and the "start" signal is probably used for ESTOP to disable the spindle.
Does that make sense?
chucktilbury
chucktilbury
Well... This is moderately embarrassing. I figured it out. I was correct in my reply to myself. It works perfectly, just as I described.
machinedude
machinedude
nothing to be embarrassed over. usually you end up getting things straight sooner or later with some time. glad you got it sorted out.
I wouldn't assume uts a TTL signal. Some have internal voltage that it higher. Ask LMS for more details. Masso outputs are not isolated so you could damage it of they use different voltage.
