New to CNC building! Estop question
clayg
clayg
When wiring the e-stop switch using a Masso controller and a Leadshine MX4660, where does the estop get wired to? Masso? or Leadshine or both? Thanks
@clayg were you able to get it working? I also realised later that if you are using an estop on the handheld MPG pendant then the wiring is slightly different, are you using one?
Just wire the +ve of the MASSO power supply from the estop button to Pin: 2 of the green estop connector on MASSO.
clover
clover
What is the logic behind the two E-stop pins - AND, OR, Xor (assuming positive logic)? My guess is OR.
Ignore the following - I should have read the manual before typing the query, the following is correct.
And am I correct in that Pin 1 is reserved for the E-stop on the MPG and Pin 2 is available for other E-stops?
Pin 1: is connected through series from the estop inputs (for MPG estop button) on the 15 pin D connector for MPG and then this signal is fed to the MASSO
Pin 2: is connected directly to the signal input to MASSO
