Hi there,
My names Jeremy from New Zealand. I have recently received my Masso. I have an older FastCut plasma table(2 axis), it was running a Testra SyncroStep controller. After getting nowhere with them I decided to upgrade! So step in Masso.
Complete CNC novice, self taught, Diesel mechanic by trade, 1500mmx3000m table, Hypertherm 1650(100amps), Proma 150 THC and a 200mm Z axis = Many questions!
I have it all wired up and working. Cuts perfectly with the THC turned off. I'm currently using Sheetcam with the Masso Post Processor.
I am running into problems with the THC. After the initial height (After pierce height) it either dives or raises to high. A question I have is, does the Masso slow down the Z speed when the THC is on? Its just something I have read regarding Mach3 and others. I have spent hours playing with the voltage control on the Proma. I can get it to work but have to continually control it via the Proma during the cut.
Ill keep pluging away, but am also curious as to any other guys that have a Masso and Plasma running. What you thoughts are, any tips, etc.
