No move..
maxime
Maxime
Hello,
I built a 4x2m plasma CNC table and already made some cut.
But this morning when I try to launch a New cut ... Nothing happen.
In fact I Can move axis with the jog and during the homing everything is ok but if I use MDI with G01x100f2500 there is a no move. And the controler didn't stop the move order using escape Key.
I made some changes during the last days installing a New thc. It's a neuron thc but this one is standalone and use only one input and one output.
I made some test but didn't find the solution.
If you have any suggestions .. feel free !!
I made a small vids :
I think you have some gcodes that are not supported, for example in line N0050 you have G40, please delete G40 and try.
maxime
Maxime
Thanks for your fast reply.
I try without g40 but no move..
But .... !! If I didn't realize the homing sequence everything move correctly !!!
maxime
Maxime
Problem solved!
I forgot to delete the z position for homing..
