Odd behaviour, is it me or my MASSO loosing it?
johnharvey
johnharvey
So I have some TTL outputs wired up to relays. for instance on TTL 1, I have the output turn on the lube pump relay.
whether from the MDI or in a program, M64 p1 will not turn on the relay, I have assigned TTL 1 as Lubrication.
YET
I can toggle the output high or low on the F1 screen and the output sends the signal to the relay, it closes, and the pump turns on. I've switched to another TTL output and it is the same behavior. I've also rebooted to no avail.
It's probably pilot error, usually is. What am I missing?
Also, my USB key board or mouse will randomly drop out at times and require me to replug the USB cables into the MASSO. This will bring them back.
john
