derekmccoy
derekmccoy
Thanks @ross I have read that guide before and Hypetherm also says to only ground at one end. However, I don't know if I'm not getting this quite right or I have a flawed understanding of what ground is, but this machine is wired as outlined in the manual figure attached below and that clearly shows (to me) grounding at both ends. Plus many other people saying to ground at both ends so you can understand my confusion I hope.
@breezy The motors are mounted to the table and therefore grounded to it's chassis (which is obviously earth grounded). The factory Sanyo Denki cable connector coming out of the encoder has 9 pins: 6 for data, 2 for DC+- and one for the cable shielding which is the thicker wire. This shielding on the encoder cable goes back to the drive and is grounded through the connector housing into the drive chassis. There's an earth ground bolt at the bottom of the drive that goes to an earth bus bar. I've checked and there's continuity between 1. the table chassis and the motor bolts 2. the motor bolts and the encoder cable shield 3. The cable shield and the CN2 connector housing 4. The connector housing and the earth terminal. I also checked the cable shield against all of them and there's obviously a connection.
Is this right or wrong? Because to me that is grounded at both ends. I have taken photos if that explains it better. Thanks for your help guys, it's appreciated.
