With the release of the Onefinity machines using the MASSO Touch controller we have received a lot of questions from existing Onefinity machine users wanting to know if they can upgrade their machines to use MASSO as well.
The answer is yes and several members of this Forum have already done so.
Please use this topic to discuss upgrade requirements and if you do an upgrade why not start a new topic showing your machine conversion process.
That way everyone can learn from each other.
It is important to understand that MASSO does not supply an upgrade kit for the OneFinity machine so it is not a plug and play process.
It is a machine conversion like any other where the installer needs to assess the current hardware and work out what they want to reuse and what to upgrade.
You will need to have and complete correct wiring for the following components
Masso controller
Power supply for the MASSO Controller
Masso closed loop stepper motors, or your own separate stepper motors and drivers
Power supply for motors/drivers
Masso homing sensors, or those of your own choosing
Custom mounts to attach your chosen homing sensors
*Masso relay module for Estop and other functions is highly recommended
*Masso pendant, to replace the joypad functionality if a pendant is wanted
To help with this we created a FAQ section that deals with the common questions related to upgrading a machine and it is a good starting point.
docs.masso.com.au
Below I have listed a selection of parts that we can supply that you may wish to consider for your conversion. You may not want or need them all as you may wish to reuse existing hardware or use alternative components.
MASSO Touch, 3 or 5 axis depending on if you want auto squaring
Please see the link below in Axis slaving to better understand why you might want 3 or 5 axis.
docs.masso.com.au
MASSO closed loop stepper motors
MASSO can provide closed loop stepper motors in 2Nm and 3Nm versions.
docs.masso.com.au
MASSO Relay module
The MASSO relay module will provide 6 relays which can be used to disable motor drives in and emergency and can be used for other functions.
docs.masso.com.au
MASSO Homing sensor
1 homing sensor is required per axis
If using the 3 axis MASSO version only 3 sensors are required as a single sensor will do the Y axis however if using the 5 Axis MASSO then 4 sensors will be required as both sides of the Y axis will require a sensor for auto squaring.
docs.masso.com.au
24 volt power supply
This is use to power the MASSO controller
docs.masso.com.au
36 volt power supply for the MASSO closed loop stepper motors
A 36 volt power supply will be requited to power the MASSO closed loop stepper motors if you are using them.
MASSO Pendant
If you want a pendant MASSO can provide one.
Please note that while many pendants can look the same on the outside, internally they can be very different
docs.masso.com.au
Jogging can be done also from the touch screen.
If you have any comments or questions please leave them below.
Masso controller
Machine conversion and Builds
Slave Axis
MASSO Closed Loop Stepper Motors
MASSO Relay module
MASSO Relay Module
MASSO Homing sensor
MASSO Homing Sensor
Powering MASSO-G3
MASSO Pendant
MPG Pendant
