Optical Tool setter
CalT
New member
Hello-
I recently purchased a tool setter that instead of the traditional mechanical switch it uses an optical sensor. I am trying to figure out how to wire it as pretty much all diagrams are based on mechanical switches. It has 4 wires in the below array:
Brown: +5 - 24V
Blue: GND
Black: NC
White: NO
I have it wired the same as a homing sensor. Would that be the best implementation? Just to be clear no resistor.
aleks88
New member
i might use a proximity sensor. i can't seem to get the proper tool setter to work with Masso it looks to complicated. it would be good if Masso had their own tool seter no complications. thanks for the reply
