Output Direct to Machine
jaykayeh
JayKayEh
I have a CNC Router using a Masso controller. I use V-carve Pro to create my cutting files and the built in Mach3 arcs post processor to create my G-code.
V-carve Pro has an Output direct to machine feature which bypasses the sometimes tedious process of manually transferring my cutting files manually to the Masso controller. Unfortunately, I cannot use this feature as it requires me to have a licensed copy of Mach3, which I do not require and would not use.
Is there a Masso/V-carve Pro was compatible post processor available that will allow g-code files output direct to machine ?
Thank-you,
Jim
if you are trying to send gcode files from PC to MASSO then the best option is to use WiFi option on the MASSO and use the MASSO Link software to drag and drop files from PC.
Please see this video
