All,
I m trying to hook up a relay to my Masso outputs for a vacuum system (it s a cnc wood router) and all of my outputs appear to be stuck in their current state. I can assign them in the setup screen, and I can invert them, but their state never changes. This applies to the TTL outputs as well as the relay outputs; I have tried using the P1-16 macro assignments as well as commands such as the flood coolant output (which is what I actually want to use).
The outputs currently in a high state are actually high and will actuate the relays, and the low states will not, so its at least correct with the state on the screen.
any ideas?
Wes
any ideas?
Wes
