buschbwbusch
buschbwbusch
I am using a PLR in conjunction with the controller on this machine. I would like an output on the Masso to make the Input on the PLR...They are the same voltage and share the same power supply. However the inputs on the PLR require a +24V to be made and the relay drive output on masso is providing a path to - how can I remedy this situation. IS there a way to change the Type of opto on the board or am I just stuck running it through another relay to make the PLR input..just seems redundant.
