Folks,
I looked over the pendant page, https://docs.masso.com.au/wiring-and-setup/setup-and-calibration/mpg-pendant , searched the forum but couldn't figure out the voltage levels on the MPG input connector.
What is the actual voltage range of MPG input pins? 5-24V
On the List of Configurable Inputs page, https://docs.masso.com.au/wiring-and-setup/setup-and-calibration/list-of-configurable-inputs , it states "INFORMATION: All Masso inputs are optically isolated and trigger with inputs from +5v to +24v", does this include the MPG input pins?
One last question, why isn't VE- wired to a DB15 MPG pin? VE- is connects through the DB15 shield. How are you supposed to make a reliable solder connection to the DB15 connector metal shroud?
Thanks for your help.
Signed,
Confused in Colorado
- the pendant page implies that resolution and axis select inputs at VE+ tolerant.
- MPGA and MPGB are only 5V tolerant - this is sort of unclear
- MPGA and MPGB input pins range is 5-24V? or are these 2 pins have extended voltage input range
- E-Stop connector input requires VE+
Signed,
