Plasma cutter firing relay
tcfengineering
tcfengineering
Hello from Sweden, just taken delivery of my Masso for a CNC plasma table I am building.
I wondered if anyone can help me select a relay to fire my plasma cutter torch. The plasma cutter needs to see a 24v signal and the manufacturer says it only needs a few milliamps. What sort of relay do I need to be buying ? would be good if it was DIN rail mounting to keep the job neat
Tim
You can use any generally purpose relay for that, as you mentioned you just need only a few milliamps to go through the contact.
For example if you are running MASSO on 24v then you will need a relay that can take 24v on the coil.
