Plasma options
cncburn
cncburn
Sn# 5A-2275 V3.33
I have been setting up my Plasma/Mill table. I will be using the Proma 150 THC, and a hypertherm 45. I recently finished building a floating torch head for my Z axis. While trying to configure my torch touch and break away switches, I discovered that I do not have the options listed in the configurable inputs. Is this something I can fix, or is it a software issue? Thank you
The software version that you are running on MASSO is it plasma or Mill?, you might have mill version loaded?. Can you please share a screenshot of the F1 screen, you can press PrtSc button on the keyboard to save the screen on to the USB pen drive.
cncburn
cncburn
I have the MILL version. Before I purchased it, I contacted Masso and described my set up (milling table that I will switch out the spindle for the plasma as needed), and was told that the 5 axis mill version was what I needed. I assumed that meant that I would have all of the functions.
You can use the mill version but that version does not have the torch related functions as its for milling, I have just emailed you the copy of the Plasma version also, please load it to the controller.
Please let us know if you have any further questions.
