Plasma Post Processor Sheetcam
5-0coyote
5.0Coyote
Is the current Post Processor on the Masso site the most current, I Thought I had seen Ross post something newer but I am having trouble for searching for his posts. Normally in forums you can click name and see posts that the person has made or commented on but I can t find that.
I would like to switch to fusion 360 but think sheetcam will be easier. I use Solid Edge to draw and its super easy.
Curt
@5-0coyote
Curt,
Fusion is great product if you want to produce a 3D model and machine it in a mill. The only time I would use Fusion for plasma work is if you wanted cut out sheet metal that was going to be folded, then Fusion's Sheetmetal worksheet is in the forefront, otherwise I would stick to SheetCam and Solid Edge.
Ross has provided a link to the post processor.
