Plasma POST Processor with THC
Ross
Ross
That is just a text document and that means it won't load into Sheetcam.
Sheetcam will only except postscript, that is why I am asking for people to go to the Sheetcam site and vote.
I hope this will help me and benefit others in the future, Masso and Sheetcam as a clean working combination.
I have searched the web and can't find a free program to change your text file to postscript, people have commented the program costs $1000s.
From Ross.
cncburn
cncburn
This may help. There is a section in the instructions that explains how to import a post from a file (pg 8 or 9).
If your download will not load as given by Masso, you can open it in Notepad++ (free @ https://notepad-plus-plus.org/), and save it as a variety of extensions.
NYC CNC has a good video on editing a post on Notepad++ He is using Fusion, but the principals are the same. Look at the last half of the video for the Notepad++ info
Hope it helps.
Ross
Ross
Thanks clover and cncburn,
But still no luck, I did do M08 M09 last week in post edit to get the scribe to work.
Not being Tec savvy it is probably best to do a vote or see if Masso will make a post processor for Sheetcam.
From Ross.
PS I like how you changed you photos in the little box on the screen.
Ross
Ross
Oh the other thing is are you able to send me a "tap file" 40mm square to compare with the one I have and I can run it in the plasma to see if it works!
Thanks in advance, From Ross.
clover
clover
I seem to recall reading on the Sheetcam web pages that they will do a postprocessor no charge - ah yes here it is:
Custom posts can be written to your specifications. This service is normally free unless the post is particularly complicated. Some examples of specialist posts include machines with multiple heads, say a plasma cutter with a pucnch marking head.
Maybe worth checking out.
Ross
Ross
Still no luck in converting the text to a script that Sheetcam can read.
clover and cncburn I spent the whole day with this.
I will probably need someone to take screen shots of the post processer that they use then I can do my editing that way in Sheetcam.
Just hope I get some help,
From Ross.
@ross those links have the proper sheetcam post processor files and work directly with the sheetcam, maybe your browser is just opening them. you need the save the files to your computer and load in sheetcam.
Ross
Ross
I managed to save the Masso as a postscript but there is no function for a scribe M08 M09.
It would be nice to have this added in the next update.
From Ross.
Ross
Ross
Scribe working only at the moment using the mach3 postscript.
"LOOKS NICE"
