segoman-designs
SegoMan DeSigns
Sounds like there is some homework that needs to be done on this...
How will I activate the solenoid valves without the M62 and M63 commands? We are talking 2 for each station (one up/down - one on/reverse)
Yes Peter your right, it's a standard Up / Down process that uses the G200 plus most of the codes following.Could you elaborate on what the solenoid actually do?
Most plasma don't operate solenoid valves as part of the plasma cutting process which is why I said you wouldn't need to use M62 / M63 but your machine must have some additional cuttings features not found on other machines.
Note: solenoids used for scribe and drill position do not count as there are automated for as part of the Tool change process.
My understanding of Lillow's THC unit is that it is a standard Up/Down THC utilizing the M667 & M666 Gcode commands just like a Proma 150 and will work perfectly with the G200 Gcode command just like the Proma.
Perhaps it is my thinking from the PP of ver 4.01 they are the commands to turn on / off the 2 sets of solenoids needed for the air drill & air scribe. we are talking 4 total solenoids (of various configurations) and air regulators that control speed & download pressure.Could you elaborate on what the solenoid actually do?
Peter suggested the following for setting up your air drill & scribe,Perhaps it is my thinking from the PP of ver 4.01 they are the commands to turn on / off the 2 sets of solenoids needed for the air drill & air scribe. we are talking 4 total solenoids (of various configurations) and air regulators that control speed & download pressure.
But you need to assign air drill to T101, one of the multi spindles, when T101 is selected the assigned multi spindle output will go high, operate solenoid and lower air drill. Then you can use either spindle output pin 2 or pins 4/5 to turn ON/OFF drill.T115 M6 for scribe
T1 M6 for drill
T112 for plasma
Know nothing about QtPlasmaC, but from your comments I take it you can write scripts to handle virtually any problem that may arise.Please understand the goal of this post is that the folks at MASSO will take a look at LinuxCNC or more specifically QtPlasmaC and try to incorporate some of its features, so please don't hate me
I should have been clearer with that statement. My point was not that QtPlasmaC lets me write a script to fix virtually any problem. I am reasonably comfortable with scripting, but that is not really what solves my biggest issues with MASSO’s plasma operation.Know nothing about QtPlasmaC, but from your comments I take it you can write scripts to handle virtually any problem that may arise.
Would, when MASSO's Lua scripting is fully implemented be able to do the same thing?
Point taken.I should have been clearer with that statement.
What do we need to do to make sure this happens? This topic has been discussed on many of occasions yet it gets kicked down the proverbial road with little attention from MASSO. After reading all of this thread it makes me hesitant to upgrade as it still has problems associated with restart. Once the upgrade process takes place I have 1,000's of cut files that become useless.Point taken.
The rest of your current post clearly spells out what MASSO needs to look at in regards to normal plasma operation.
Yes, you are right, but once done it works fine.Dingo,
Without the G200 and tool selection commands on the older files they will no longer be a useful cut file. The Time it would take to upgrade the original files for cutting on the latest firmware, one could take the original art files and run them through the new PP much quicker.
It would take less than 30 seconds to put MASSO into Legacy mode.Dingo,
I want to clarify that I am not saying MASSO is causing every situation where I need cut recovery. A plasma cut can stop because of a consumable problem, failed pierce, loss of arc, material movement, collision, air issue, power-source issue, operator feed hold, or several other things that have nothing to do with the controller.@fablab, My biggest issue with MASSO plasma is cut recovery.
Have you worked out why you would require cut recovery on duct work.
For over 27 years I would have only had to restart maybe 7 times, the cuts were over 4.2 meters in length.
Sometimes a simple switch can help with the restart process.
If you are having the problems you specify, go back to the source, it maybe related to your equipment.
I don't believe there is anything wrong or can't be worked out in the Masso G3, it's up to the individual to solve their own problems.
Works fine for my situation.
Cheers.
