Power and Common
jcapitao
JCapitao
Hi everyone
Quick question. I used an old 5V phone charger as a power supply for my homing signals, and got no response from the Masso controller (HIGH/LOW) tell-tale. As soon as i give the homing signals power directly from the MASSO controller, then i get a response. Is it because the old phone charger puts out only 1 amp?
Also, there seems to be only 1 "common" terminal on the MASSO, which is the negative on the power supply. Can i use the "GND" on the SERIAL terminal block as a common as well??
JC
have you connected the -ve of the 5v phone charger and the -ve of MASSO power supply together? if not then you will need to do this.
jcapitao
JCapitao
I will measure and let you know soon.
Have you had a think about my question regarding the "common" terminal on the Controller?
