Power supply
aleortaqro
AleOrtaQRO
I'm not sure about which model of power supply to use, because the instruccion of masso 3 is a power supply between 12v- 24v with a minimum current of 1.5A
i've done a quotation of 3 power supply
60W 24v 3A brand weidmuller
30W 12v 2.6A brand weidmuller
25W 12V 2.1 A brand weidmuller
someone can help me to choose the best power supply to energize or if you know other model ?
@aleortaqro
Make a list of the components you plan to connect to the Masso controller. Add up the total current needed for all those components and multiply the total sum by 2. That should give you a good place to start.
I use a 12v DC 5 Amp Mean Well power supply (MDR-60) on my Masso controller. It also runs all my accessories like the red yellow green lights as well as the relays for the mist coolant and spindle drive control. Its overkill for what I need but that also made it very reliable with room to grow.
