Price THC
justingro
Justingro
Hi guys.
When wiring up and setting the masso up for THC using hyperthem plasma how would I connect the plasma to price unit and plasma to start plasma have an idea of the 50:1 connection but not quite sure on outputs on masso
Many thanks Justin
@justingro
Justin,
Thanks for providing the manual, I re-read your question and at this point I don't know enough about wiring the plasma side of THC, Hypertherm and MASSO.
The outputs on MASSO vary between G2 & G3. If you have G2 you can use relay outputs 1 to 6, but G3 will require TTL compatible relay card to connect MASSO outputs.
Connecting Price THC outputs to MASSO inputs will be the same as Proma Compact, as Price hasn't indicated any polarity on the ARC_OK, UP, DOWN signals. Just connect all black wires to negative common.
This drawing from Ross will help.
If you need further help put a shout out to Ross, I'm sure he will help.
justingro
Justingro
Hi Breezy.
Thanks for the reply I know there are a few price units on this forum and i am reading and waiting to see if they come right but I think I? should just buy and try
Justin
Ross
Ross
Justin, in my thought Most THC,s will be the same in principal.
Just follow the diagram that Arie showed and it should be ok,
Shield and ferrite everything to get rid of the noise.
On the forum search "Ross" i have put a bit here aswell.
On YouTube search "Ross Woolley" look at my video it will help ?maybe?
Thanks Arie always good to here from you.
Good Luck.
5-0coyote
5.0Coyote
Quote from Justingro on March 17, 2020, 9:38 pm
Hi Breezy.
Justin
Justin any luck with the price? I m looking at the same price, Masso and hypertherm with cpc port
Hi Breezy.
Justin
justingro
Justingro
Hi coyote.
No no luck yet I am still waiting for mine to arrive it's sitting in Dublin post office but all the posts on the price THC just seams to dry up on this forum so I guess it just buy and try at this moment but as soon as mine arrives and I testing I'll let you guys know
Cheers Justin
