Printed version of the Masso Documentation
For a while now users have wanted to get a downloaded version of the Masso Documentation to print out to put on a tablet device to take out to the workshop while working on their build.
We are pleased to announce that this is now available.
https://docs.masso.com.au/
We have created a new documentation platform which has at the top right of the page a PDF download button that you can click on and it will download the entire documentation.
As you know videos form part of the documentation and while these are not downloaded there is a QR code generated for each video which you can scan with your phone or tablet and it will take you to the video.
As the documentation is updated the we will update the PDF also.
We hope you enjoy the new documentation.
All the best from the Masso support team.
peter35
Peter35
Have just had a quick look, looks good and l like the links to YouTube, however l believe information still needs to be in the manual.
As an example. 4.3 admin and passwords. without going to link on YouTube, there is no information given. you need to explain how you change password etc.
4.4 graphic interface, again would be good to have screen shots in manual.
qr links are good if you have good internet, but not always available and watching YouTube whist trying to sort out a problem at the machine is not always practical or quick.
Just trying to give some constructive criticism.
segoman-designs
SegoMan DeSigns
Definitely a step in the right direction, as Peter35 says internet is not always available. Perhaps you should give the file a version number (V.01) then change it when you upgrade it for reference purposes.
Hi SegoMan DeSigns
Each PDF file already has a version number at the bottom of each page and the date the PDF file was created.
Now that the new platform has been created we will start to add more information to the pages with just videos and add even more.
segoman-designs
SegoMan DeSigns
Peter,
The version is visible on the document when it is opened, I was thinking of the Ver # on the download file itself then you would know if you need to download it or not.
Documentation bugs: v5.8 - 30 Sep,2020
Multiple locations: Typographical error
"F Value The F value defines the federate at which the axis will move at. If the F value is not specified then the feed rate used from the last Gxx command is used."
Page 102 - Hard Limits
"The homing inputs double as hard limit inputs after the machine has been homed. To work, all hard limit switches must be outside the envelope of axis travel or the hard limit will trip before it reaches the full travel of your axis. Soft limits should be used first and Hard limits as a last resort. Tripping a hard limit will not instantly stop the axis but it will decelerate to a stop. Hard limits can be disabled under general settings.
Hint: if you mount your homing sensors/switch on the moving carriage and put a trigger at each end of the axis travel then only one sensor/switch can work for both homing and Hard limit triggering at each end of the axis travel."
No information on how to configure an input as a hard limit (use case: switch at minimum and maximum travel, configure one for home but how to configure the other?).
Should the additional hard limit input be configured as "<axis> Motor Alarm Input"?
Hi ZombieEngineer
There is no configurable hard limit inputs. The Homing inputs double as hard limit inputs.
If you need a switch at each end either series or parallel the switches on the homing input as needed or follow the hint and use 1 switch and trigger it at each end of it's travel.
PS the Federate has been fixed. All 5 of them.
To be honest I have found the documentation a struggle to use efficiently, combination of order in which information is provided and missing bits of information.
Yes - Section "5.5 Homing Sensor Identify & Connect" does contain the relevant information but it only uses the term "Homing" with no reference to "Limit". A review of the "5.2 Setup MASSO Mill" mentions "limit switches" but does not list "homing switches" (a similar inconsistency between "drives" and "Axis Servo/Stepper" as Drives could also be referencing a VFD).
EDIT: In my opinion "5.5 Homing Sensor Identify & Connect" should be merged with "9.12. Homing / Home Inputs".
I would be re-writing the "Getting Started" sub-section of the "Setup MASSO Mill" as follows:
Getting Started​
To configure MASSO you first need to connect a minimum of following items:
Ideally you would also connect your:
You can connect these as you configure each of these components.
I was scratching my head to figure out if "Auto touch off" referenced "Touch Probe", "Tool Setter / Touch Plate" or "Automatic Tool Length Calibration". For the second group of items (E-Stop through to VFD) the details are in different sections of the documentation ("Setup and Calibration", "Quick Start Guides", etc).
EDIT: The current sections "12. Tool Setter / Touch Plate" and "13. Automatic Tool Length Calibration" should be merged into a single section. The first section is the wiring while the "Automatic Tool Length Calibration" is the configuration. The combined section should be moved under "9. Setup and Calibration" as this deals with wiring and associated calibration.
EDIT2: Section "12. Tool Setter / Touch Plate" appears to be a poor copy of section "11. Touch Probe" as it directs the user to configure the input as a "Probe Input Signal" instead of a "Tool Setter Input" as mentioned in the video tutorial.
There appears to be a duplication in the documentation:
"3.5 Loading Software to MASSO-G3" versus "4.1 Loading Software to MASSO-G3"
"3.6 Loading Software to MASSO-G2" versus "4.2 Loading Software to MASSO-G2"
In the PDF the conversion of the "Powering MASSO-Gx" sections has resulted in half a line of text in superscript. Looks like a common fault wherever bold has been used.
