Problem cutting Circle
danielsun
DanielSun
at first i like the controller, this was one of the easiest setups i ever had and i had a few of them.
But I have a Problem.
I made a small program but it seems that it not work right.
Milling a square works, but milling Circle's does not work. I mean G17 G18 and G19 I'm not sure (one of this) :) but the controller did not make it. I made a fusion 360 Code with the build in masso postprozessor.
here a video what happens, (i'm milling in the air for testing).
i also uploaded the video
Help would be great, thanks
Best wishes Daniel
(1001)
(T1 D=10. CR=0. - ZMIN=-18. - SCHAFTFRSER)
N10 G90 G94 G17
N15 G21
N20 G28 G91 Z0.
N25 G90
(2D-KONTUR2)
N30 M5
N35 T1 M6
(3 Z SCHRUPP HOLZ)
N40 S24000 M3
N45 G54
N50 G0 X68. Y237.34
N55 Z15.
N60 Z5.
N65 G1 Z1. F2500.
N70 Z-17.
N75 G19 G3 Y238.34 Z-18. J1. K0. F7900.
N80 G1 Y239.34
N85 G17 G3 X67. Y240.34 I-1. J0.
N90 G2 Y370.34 I0. J65.
N95 Y240.34 I0. J-65.
N100 G3 X66. Y239.34 I0. J-1.
N105 G1 Y238.34
N110 G19 G2 Y237.34 Z-17. J0. K1.
N115 G0 Z15.
N120 G17
N125 G28 G91 Z0.
N130 G90
N135 G28 G91 X0. Y0.
N140 G90
N145 M30
Hi @danielsun
Not sure what is going on with your machine because I ran the file you posted here and it moved to the starting point, made a circle and returned to the home position as per the Gcode.
As far as I can tell it is doing what it should and does not behave as you show in your video.
Can you please provide a copy of your printable settings file.
danielsun
DanielSun
Hi Peter,
thanks for your answer the last night i found the reason.
G1 codes was not execute and the reason was in the general settings the max feedrate was 0 so only the G0 codes was excute.
Now masso runs great, realy.
Now I make a few tests and i think as oem this will be a new controller for my CNC.
Tanks
