problem with 4 bit tool changer for lathe
hectormendez
hectormendez
hola buenos d as a todos, alguien ha tenido problemas con el cambiador de herramientas de 4 bits para torno, tenemos las salidas asignadas como se ve en la imagen y simplemente no funciona?
es un denfor torno triac
Translation by MASSO Support.
hello good morning everyone, has anyone had problems with the 4 bit tool changer for lathe, we have the outputs assigned as seen in the picture and it just doesn't work?
it is a denfor lathe triac
hectormendez
hectormendez
hello ventoso,
after making some changes, I got the turret to rotate,
when I order a tool: example T4M6 my assigned signal 8 of masso
is activated which is where I assign output 1 of the tool changer and the turret remains rotating.
Yes, I have inputs assigned, I will leave an image,
I suspect the problem is the order of my inputs,
I will leave a second photo of my control box so you can take a look at the 4 bits.
I also leave you the diagram of the tool changer of my lathe.
hectormendez
hectormendez
Nueva actualizaci n, como antes mencione, logre hacer que la torreta gire, era un problema de cableado en las salidas, ahora gira pero no se detiene, ya tengo asignados bit1 a bit4 en en las entradas de masso 13 a 16, en la entrada 17 tengo asignado el clamp de la torreta, asi como se ve en el video.
Existe alguien con ustedes que me de soporte en espa ol hay chicos con masso en america latina tambien.
Translated by MASSO Support.
New update, I managed to rotate the turret, it was a wiring problem in the outputs, now it rotates but does not stop, I already have bit1 to bit4 assigned in the inputs from masso 13 to 16, in input 17 we assign the turret clamp , as seen in the video.
There is someone with you who can support me in Spanish, there are also boys with masso in Latin America
hectormendez
hectormendez
After spending time trying to figure out what happens with my tool change,
I begin to suspect that the 4-bit signal output turret comes with a programming error,
I already reworked the connections several times as indicated in the documentation and it simply does not work.
hectormendez
hectormendez
Cita de Breezy el 11 de marzo de 2021, 11:00 a. M.
@hectorm ndez
H ctor,
Se mueve la unidad cuando aplica se ales a las entradas CW y CCW?
Ha asignado las entradas? No puedo decirlo porque la ventana de asignaci n de la funci n de salida est oscureciendo la lista de entrada.
Saludos,
Si, he asignado entradas, puedes ver las im genes que he publicado por favor,
Hi Hector
I had a look at your video and did a frame by frame of it to check the logic sequence and it looks like the input progression is correct.
Can you also provide a copy of the Settings and tools files from your MASSO
Can you provide a copy of your Printable settings file as well.
hectormendez
hectormendez
Cita de CNCnutz el 15 de marzo de 2021, 7:23 pm
Hola hector
Ech un vistazo a su video e hice un cuadro por cuadro para verificar la secuencia l gica y parece que la progresi n de entrada es correcta.
Tambi n puede proporcionar una copia de los archivos de configuraci n y herramientas de su MASSO?
Puede proporcionar tambi n una copia de su archivo de configuraci n imprimible?
Saludos Peter
Hola Peter, gracias por responder aqu est n los archivos solicitados,
env a un correo electr nico con los tres archivos completos
ya que el ltimo es un archivo .txt y no se carga aqu .
NOTA: hay algunas configuraciones que a n tengo que completar.
  • MASSO_Lathe_2-Axis_Settings.htg
  • MASSO_Lathe_2-Axis_Tools.htg
