Proma pierce, nothing else.
Ross
Ross
All help is much approached with this.
The g-code is a post I am using from Sheetcam with m codes changed to run a scribe, cause I couldn't load the Masso to Sheetcam.
Plasma is Jasic cut100, no 50 to 1.
What happens is the g-code runs ok (full cycle) when the plasma is off, touch trigger relay works how it should but the plasma tip sits about 4mm from work piece.
When plasma is turned on the program will run too and pierce work then stops there, tip is still about 4mm from work, Sheetcam setting is 1.5mm.
What I think I need is screen shots of the f1 settings and the Proma settings as well cause it said something about torch height in that as well.
I have included the 40mm x 40mm text file.
"N0100 is the last line it reads"
Thank you to all that can help with this in advance,
From Ross
N0010 (Filename: 40 12hole.tap)
N0020 (Post processor: Masso plasma THC with scriber and backlash compensation.scpost)
N0030 (Date: 23/10/2018)
N0040 G21 (Units: Metric)
N0050 F1
N0060 G53 G90 G40
N0070 (Part: 40 12hole)
N0080 (Operation: Outside Offset, Colour 7, T2: Plasma, 1.5 mm kerf)
N0090 G00 X19.2600 Y24.8246
N0100 G38.2 Z -65 F500.0
N0110 G92 Z0.0
N0120 G00 Z1.5000
N0130 G92 Z0.0
N0140 G00 Z3.0000
N0150 M03
N0160 G04 P0.5
N0170 G01 Z1.5000 F300.0
N0180 X18.3654 Y25.9904 F3000.0
N0190 X18.5572 Y27.4473
N0200 X19.9631 Y29.1389
N0210 X21.8521 Y30.2656
N0220 X24.0086 Y30.6987
N0230 X26.1862 Y30.3887
N0240 X28.1362 Y29.3710
N0250 X29.6357 Y27.7619
N0260 X30.5136 Y25.7451
N0270 X30.6696 Y23.5511
N0280 X30.0858 Y21.4305
N0290 X28.8289 Y19.6254
N0300 X27.4441 Y18.5628
N0310 X25.8760 Y17.9133
N0320 X24.1933 Y17.6918
N0330 X22.4628 Y17.9196
N0340 X20.3371 Y18.9508
N0350 X18.7197 Y20.6729
N0360 X17.8236 Y22.8590
N0370 X17.7670 Y25.2208
N0380 X18.5572 Y27.4473
N0390 M05
N0400 G00 Z12.7000
N0410 X51.0567 Y-1.9200
N0420 Z3.0000
N0430 G38.2 Z -65 F500.0
N0440 G92 Z0.0
N0450 G00 Z1.5000
N0460 G92 Z0.0
N0470 G00 Z3.0000
N0480 M03
N0490 G04 P0.5
N0500 G01 Z1.5000 F300.0
N0510 X49.6990 Y-1.3576 F3000.0
N0520 X49.1367 Y0.0000
N0530 Y48.3867
N0540 X48.3867 Y49.1367
N0550 X0.0000
N0560 X-0.7500 Y48.3867
N0570 Y0.0000
N0580 X0.0000 Y-0.7500
N0590 X48.3867
N0600 M05
N0610 G00 Z12.7000
N0620 X0.0000 Y0.0000
N0630 M05 M30
cncburn
cncburn
I m a newbie with my own plasma issues, So use this info accordingly. Is your software the plasma or mill version? I don't see any M667 THC ON or M666 THC OFF. Good luck.
Ross
Ross
m03 and m05 turns torch on and off,
I am using the mach3 plasma with scribe with backlash compensation post script and edited the G & m codes to suit Masso.
The scribe works, the plasma will do a pierce and stops there.
Not sure if the coding is wrong! but people on forums that I have read all point to the Proma settings.
That is why I would like screen shots of F1 showing the settings and also the settings from the Proma!
If Masso had a post script and not a text document I could load it into Sheetcam, but I still need a scribe on off with M codes like "M10 M11"
at the moment I use m08 m09 for the scribe.
The best is to have a post script from Masso including Scribe M10 M11 in the relay column, added to the "Masso Plasma"
From Ross.
@ross first question, are you using THC to control the Z axis to maintain the gap or you simply want to do a touch off and then goto piercing height, start the plasma, wait, then goto cutting height and sart cutting?
Ross
Ross
Hi Masso,
I think, do a touch off and then goto piercing height, start the plasma, wait, then the THC controlling the cut height.
Thank you.
Ross
Ross
Hi Masso,
Here are the settings I use.
It does the pierce in the form of a dot on the metal and that is it.
Thank you from Ross.
  • MASSO_Settings.htg
Ross
Ross
Hi Masso,
I think the resistors are correct.
When I do a test run with the Proma I get voltage ark high and the up/down work in the F1 screen, but no movement in the jog screen from Z axis or from the table Z.
From Ross.
Thanks for the settings file @ross and they look good.
  1. Can you double check that you only get all the inputs as HIGH only when they are triggered.
  2. Can you please share a very basic (minimal) gcode file that you are running, maybe just make a 100 x 100mm square.
  3. So does the torch come down, touches the piece and then nothing happens, no alarms nothing?
Ross
Ross
All inputs are set to low and change to high when triggered.
Plasma fires and just puts a hole in the metal, No alarm goes off.
Have two files attached, both act the same Mach3 and Masso postscripts.
Photos show tip height where it stops and photos of the signals.
Thank you from Ross
  • 100mm-x-100mm-Square.-Mach3-edited.tap
  • 100mm-x-100mm-Square.-Masso-edited.tap
thanks for the gcode file and it ran good on the machine, so it's not a gcode issue.
We think MASSO is not getting the arc ok signal, please run the file and wait for about 20 seconds and if MASSO does not get an arc ok signal you will see an alarm flashing on the screen.
Ross
Ross
Hi All,
This is were I am up to at the moment and have no idea what I am doing!
I have put about 60 holes in the metal now and each time I have changed the Proma settings.
I do get the ark not ok signal, but like I said I have no idea how to solve the problem.
I think it is best if someone can send me the settings to fix the problem.
Machine: Cut 100 using full voltage to connect the Proma.
All help is appreciated.
From Ross.
So the PROMA is not giving the arc OK signal, have you tried contacting PROMA?
As a test please goto F1 screen and invert the ARC OK signal so that MASSO gets a dummy signal, with this MASSO will think that its got the ARC OK signal and will start the cut.
Ross
Ross
After reading lots of forums it looks like it would be a waste of time trying to contact Proma cause no one gets a reply from them.
I have posted a drawing if what is happening in the way of problems.
Like i have asked before I need some one to share their settings with me to see if that will help solve the problem.
E.g. Proma and Masso Z feed and speeds.
Thanks again from Ross.
can you check with a multimeter that the PROMA even gives an arc ok signal.
Also as mentioned earlier, can you please invert the arc ok input on MASSO to bypass this input and do a cut as a trial.
Ross
Ross
Hi All,
I have posted a drawing of the cutting with arc ok inverted, showing high and low.
Will check with a meter as well.
Ross
Ross
Hi all,
Today I have the plasma turned on, F1 screen, masso set to proma thc on.
F1 screen 'arc ok + thc up and thc down set to low.
I start the program and the plasma strikes an arc and just sits there just burning a hole.
Arc ok is working showing high RED, with both the thc going from high to low signals working as well, showing in the F1 screen.
These are the tap files I have tried and I am now wondering if I have the wiring OK?
Thanks to all that can help me with this.
From Ross.
  • A-line-50mm-mach3.tap
  • A-line-50mm-masso.tap
  • A-line-50mm-mach3-no-delay.tap
  • A-line-50mm-masso-no-delay.tap
same issue @ross, you need to set arc ok input to HIGH because you are not receiving the signal from PROMA and until this is set to high your cut wont start.
