Well Ben, I think my problems are over!
But I don't get movement of the Z axis in test mode with the THC.
I use the Proma 150thc But I am thinking have you got you ark OK set to high, that works.
If mine is set to low it moves to start position fires the pilot ark for about 3 seconds before moving the x down to the job, Then it does a full dry run.
If I need to do a practice run with the plasma machine off "I need to F1 turn thc and ark ok off".
All wiring to do with the plasma is shielded and I have a separate power supply for the Proma but you have to run a piggy back wire to the Masso power supply, I use "24v to 24v + to +, - to - "one off each. and choke these wires as well.
I even took the advice from another member and grounded the X gantry to the table.
Good luck from Ross.
Ps; If you get frustrated with it just choke it some more!!
