Proma THC - I get a flashing thc animation on the Proma
jgsculpture
jgsculpture
Hello
My Proma THC flashes thc when switched on - its as if its not able to self calibrate. This has only just started to happen.
Some times it works as normal and some times it flashes.
Its running with mach3
Im very new to this and the machine was bought secondhand.
All advice is very welcome
Ross
Ross
Hi.
Just a few ideas i think might help.
Ground rod that goes through the floor, might need water to moisten the dirt. If dry it causes electrical noise.
Check that wiring connections are tight. They do come loose from time to time. As i have found out in the past.
You can look at my videos on YouTube For wiring and grounding. "Search Ross Woolley"
hope it helps Ross.
grebbo
Grebbo
Hi jgsculpture,
couple of questions to start regarding your set up, is your Proma THC running on a separate (dedicated) power supply? where is the Proma located? (near the plasma cutter?) and are you running a voltage divider or straight out from High Voltage. Check all of your connections especially on the Proma as you might have a loose wire and like Ross mentioned proper earthing is the key - post some pics of your set-up to help us diagnose
jgsculpture
jgsculpture
Hello
thank you for all the suggestions and ideas. After some thought Iv decided to upgrade the plasma, the THC and the blackout board.
thank you again for all the comments.
john
