Radial tool changer
sizigi
Sizigi
HI
I have an EMCO VMC100 that uses a radial tool changer I don't think that the logic for the umbrella tool changer will work as the tool rotation is done by the spindle motor but I think it could be modified to work with out a huge amount of work.
Interested to see if any one else has one of these machines
~Sizigi
sizigi
Sizigi
here are the sections from the service manual that explain the tool change process
this is a video from a guy that worked out the logic for a Mach conversion some one did
~Sizigi
geoman
Geoman
Hello Sizigi,
I also recently purchased a used EMCO VMC100. Still setting it up. I'm curious how your MASSO retrofit to this machine went. Anything that you can tell me would be greatly appreciated!
Kind regards,
Tony
carre-olivier
carre Olivier
Bonjour Sizigi,
J'ai la m me machine, je souhaite savoir si MASSO contr le bien le changement d'outils.
Merci de partager votre exp rience.
Olivier
