beyondthegreystategmail-com
beyondthegreystate@gmail.com
Hello
I have problem with masso as it as no rapid movement feed rate i believe. So even the machine homes and machine work with manual controls as soon as i try to run the gcode file or the probing routine or even the mdi commands the machine doesnt move or gives any error. i think it is because there is no rapid feed rate set. Can somebody help me with the issue.
when i run the g code the spindle turns on, but the machine just sits there there no movement or even error or alarm
Thank you
Thank you
