An alternative relay module that can be mounted remotely from the G3 MASSO controller with minimal wiring.
Use an existing TTL digital output to provide a serial signal to a remote relay board (single wire controlling 6 or 8 relays).
Optional hardwired E-Stop input that when not active results in all relays turning off or if the serial data from the G3 MASSO controller stops for more than a predefined period (> second?) the remote relay board goes into ESTOP and the relays turn off.
This would allow relocating the relays with minimal wiring (MASSO Touch).
