Report your v5.04b Bugs (Now closed)
Status
Not open for further replies.
Thank you for being a Beta tester.
If you find a bug in this software version please report it here by making a new topic in the 5.04b forum.
Create 1 topic per bug and put the bug description in the topic heading as it will make it easy to find.
Reporting it in MASSO Lab will alert other users to the problem.
  • Like
Reactions: 900
ohsnapfit
Member
If you have the file edit page open while running a code and press the e-stop, the screen freezes.
ohsnapfit
Member
When I run a program, and it completes (M30), I press cycle start again, and it doesn't run again, I have to go and re-load it from the F6 page.
Thank you for the report.
Could you eloborate on this please.
Under no circumstances should you be editing a file that is being machined.
Can you explain how you got into editing while the machine was running please?
Regards Peter
Could you share a copy of the file you were running that exhibits the problem you are having se we can test it.
Regards Peter
ohsnapfit
Member
Could you sahes a copy of the file you were running that exhibits the problem you are having se we can test it.
Regards Peter
It wasn't fully repeatable, cycle start worked later on in the night, so I am not sure it was the file. If I can isolate the conditions, I will report.
ohsnapfit
Member
Regards Peter
To be clear, I wasn't trying to edit on the fly. The edit code screen from F6 doesnt go away when you go back to the run code screen, thats how I got into that situation
njesr63
New member
Has the active program line tracking been addressed in the updated version? If so, mine is still not tracking correctly. I am testing a 3000 line program on the first run and it is executing lines that are not yet showing on the screen. Makes it difficult to troubleshoot when running single line.
njesr63
New member
Peter,
Found two other issues.
First. When my controller stops at the M1 command and I select single block, the program resets.
Second. When I use the Jump to Line, the controller starts normally from the line I input. However, the screen freezes and will not track.
Thanks,
Nick
Hi Guys,
I badly worded this topic and did an even poorer description in the text portion of my post.😔
I actually meant to say make a new topic for each bug in the MASSO Lab 5.04b forum topic and not add all bugs to this particular thread.
My fault entirely.
I will lock this thread and make new topics for each bug report you have raised.
Thanks for your support in this.
Status
