Retrofitting Plasma Table with JMC AC Servo Motors
altea17rosa111
Altea17Rosa111
Hello,
I've been asked to retrofit a Plasma Table and I used to modify all the framework, I'm expert in cabling and engineering even if I'm still learning about AC Servo Driver.
At the moment I can do some tricks directly from Servo Driver but I'm not able to establish a good communication with MASSO G3, then I've to ask following questions, that's because my motor can't run as fast as I would, then let me ask:
  • is JMC motors & driver good to be used with MASSO?
  • I've to move a machine of 450kg
  • I'm using mechanical reduction 45:1
  • actual motors are 2.39 N/m
  • Motors power are 750 Watt
I really need to have some consultancy also under payment, that's because I need to finish the machine in 1 month,
thanks Ivo
gsuper7
gsuper7
Hello Ivo,
Could you please clarify if the gearbox is driving a Trolley Wheel or a Pinion Drive & Gear Rack? Moreover, do you know any of the following specs: Max trolley's desired speed, Motor's desired RPMs, Wheel's active Diameter or Pinion Drive's Dp (or Rack's Module and Pinion Teeths' Number)?
I could do some mechanical calculation checks for you...
George
